GS 911 Taunton area?
Fluffy Bridges
South West Wales
57 plate, non-servo, GSA, 21,000 mls, regularly serviced, mine from new.
Fired her up this morning for run to parents in Dorset. Red brake failure light came on and stayed on there and back but no appreciable loss of braking performance either front or rear. Didn't use them hard enough to check the ABS performance so I need to check out the problem.
Speedo working as normal, red warning triangle extinguishes on start up also as usual, brake light appears normal.
Any one got a GS 911 in the Taunton/Exmoor area able to read the fault codes?
Beer available as "thank you":thumb
Any and all help most appreciated.
Fluff.
911 Available
If you don't get any closer offers Fluffy, I'm just inside Cornwall. 'Bout an hours ride, you're welcome to use it any day or evening.
Steve.
That is extremely kind. I'll see how things pan out and go from there. Will be in touch.
Thanks Steve
Simon.
Thanks Bendy.
I'll have a crack at it this w/e. I've got a list of things to check before resorting to Steve's kind offer
Simon.
