Im not sure how the canbus components are wired. Is there a normal 12v 2 wired feed to the horn from the box of tricks? It's the best bike horn I've had and i'd like to fit one on my Triumph.
Electricity is electricity and a horn is a horn.
All you'll need to watch out for is if your third party horn draws more than the existing BMW horn and as an consequence (maybe) causes the canbus 'fuse' to trip. If it does, fit a relay.
^^ Correct![]()
I wasn't sure what the setup was. Is it the 3 wire canbus thing between controls and ECU, then the ecu sends a good old 12v power to the horn. Or is the horn on the canbus loop?
I have a Stebel 136db low tone horn on my bike. It fits in the original position, i used a connector from nippy normans to plug in to the standard harness. Works no probs and a lot louder!
I have fitted a Stebel Magnum and the connector from Nippy's, to the original harness, however It trips the Canbus if I press for more than a few seconds.
Any advice would be appreciated.
Regards,
John
If the new horn is cutting out after a few seconds, this is because it takes more current than the Canbus system allows, so it trips its internal fuse. When you switch the horn off the fuse resents.
The only way around is to use the horn supply lead to activate a relay, then the relay can operate your new horn.
If you have both horn still connected remove the original horn.
Oh er missisIf the new horn is cutting out after a few seconds, this is because it takes more current than the Canbus system allows, so it trips its internal fuse. When you switch the horn off the fuse resents.
Hi SMB,
I have removed the original horn but used the existing wiring together with the Nippy's connector that gives spade fittings to connect the Stebel.
Do you think that I need a relay. (what type/size)
Regards,
John
Yes, any 12V automotive relay will sort it out, either from Halfords or Maplin.
The Nippy lead can be used to trigger the relay.
Take a fused +12V supply from the battery to the relay, then the switched relay wire to the horn. The negative wire goes from the battery to the negative of the horn.
So the new horn would be taken out of the Canbus system.
If you were nearer I would do it for you, but Devon is to far away.
The
On my 2014 GS LC,
The horn is a 2 wire 12V job.
I replaced the horn with a 12V relay that triggered the new horn. As the relay worked and did not bounce the connections I believe that the supply to the horn is a steady 12V.
So you should be able put it on your Trimuph.
SMB
Thanks SMB, I'll keep an eye on eBay for a second hand GS LC Horn. Its for a Triumph Scrambler.
Mine doesn't. Its the most effective bike horn i've had in traffic.
