Hi, how does the clock bezel come off the bike? I've removed the screen and exposed two bolts just above the headlight. Removed the bolts and the bezel is loose but doesn't lift up. I'm trying to replace the neutral bulb. Also the sidelight and dipbeam aren't working. Highbeam and tail light is fine. Any ideas? If it had just been one of the sidelight or dip beam lights not working, I'd assume a bulb had gone but with both not working, I wonder if if could be something else?
