sevenfifty
Hi, I've got very strange electrical problem and need your advice please.
When key is ON everything works fine - blinkers, high beam, horn etc
Just after i push the starter button and engine start working all disappear - no blinkers, no high beam, no horn, no heated grips, i can't change the trip computer also. Handlebar controls just doesn't works.
Only low beam works and that's it!
Luckily I have a GS 911 and the following error fault was reported:
Fault Codes Report
41758: Battery Positive (KL30) over-voltage
This fault occurred 31 times.
The fault is currently present.
Also apply screenshot that shows that according live data ZFE voltage values are too high when the key is ON and the engine is not running.
How could it be to show so high voltage until the engine is not running?
Please help with this weird problem!
Thanks in advance!
Fault Codes Report
Thanks in advance!
