Hall Sensor Repair
Chewbacca
Duleek, Ireland
Hi,
I am thinking of repairing an old hall sensor from an 1150GS, found a link on the site, but this refers to an 1100, and I see from Motorworks that there are two differens sensors available.
Anyone know if the same hall sensor is used on both bikes or what the difference is?
http://www.ebbo.org/2av54.php
http://www.newark.com/jsp/search/productdetail.jsp?sku=96F1986&_requestid=32418
Wonder if the same sensors are used, or if it is the adaptor plate that is different. I see the connector seems different at the bike wiring end. A pair of sensors cost about £35 when compared to about £150 for the new part.
http://www.motorworks.co.uk/bmw/pro..._20&header_text=&header_text_image=0&spPage=2
The Honeywell 2av54 Hall Effect Switch
Could start a cottage industry repairing these as there are a lot of broken ones about!
Even cheaper - a lot of the failures are due to the wiring deteriating through heat and age.
got mine just waiting for a plate to come up then will rewire with new sensors
got mine for £26.00 posted
Hall Sensor repair
Don't tell me your one is after breaking! I might try to fix my old one up too, let me know how you get on...
Hi Pat,
I will be using your old one as a template for repair!!
A spare for the Alps!:thumb
Hi
1100 or 1150? The same type sensor? Honeywell 2av54 Hall Effect Switch?
I see from your profile it is a 1100, intersting to see if they are the same sensor.:tumbleweed:tumbleweed:tumbleweed
