Sorry guys, but it would appear that some skill is still required to ride a bike
Yup What I said.
Yup What I said.
Pukmeister said:The way I read this is:
"Sorry everyone, but we have unfortunately over-servo'd the brakes on our bikes so they stop really well in normal use. Grabbing a handfull however will definitely lock up your front wheel, causing the ABS to release and reapply, by which time you will be half a mile further down the road than normal and in need of fresh underwear."![]()
What I want to know is how much power:
Chisurz said:OK - The way I read the insert is as follows: "During rider safety training... the battery is put under heavy load by the ABS control actions, but... is not being recharged as practically no riding is being done... this... situation... can bring th ABS up to its technical limits in which its... function is no longer fulfilled" - and the rider ends up no servo ABS...
It goes on to say "ride... over sufficient distance to recharge the battery afer a maximum of five braking exercises... switch off consumers such as... grip heating" etc. etc.
To me, the implication of this are (1) that if the battery is in a low state, for whatever reason, the servo ABS is not going to function properly (2) braking with servo and ABS control functions takes more out of the system than the alternator can put back, hence the drain on the battery.
Someone tell me why I'm wrong, please, as such a design totally sucks...
So for the five years that EVO-brakes have been around neither the design muppets nor any of the customers have been using the bikes in real-life situations? Well that would of course explain why we havent heard of the extreme unsafety with these brakes during all the previous years.Chisurz said:The design muppets clearly don't use the bike systems they knock together in real-life situations
SpyInTheCamp said:Am I supposed to feel left out as I haven't received this yet?![]()
Kai
Starman said:I
All very well, however one paragraph seems a bit scary:
'In emergency braking as it is often taught, in which the brake pressure is generated as quickly as possible and with all possible force, the dynamic load distribution cannot follow the increasing deceleration and the braking force cannot be completely transferred to the road. The ABS has to intervene to ensure that the front wheel does not lock up; this reduces the brake pressure and the braking distance is extended' !!!!
Chisurz said:Engineers - thanks - looks like mine won't have servo-ABS at some point either, so we'll be in the same situation!!
I can accept that this specific situation is unlikely, although someone using the machine for lots of short journeys in an area where they need to use the brakes a lot, including at standstill, could presumably be at risk of system failure... The design muppets clearly don't use the bike systems they knock together in real-life situations
So, I'm still no closer to understanding the performance parameters and limits of the design...
Any more offers?
Pukmeister said:Just because ABS failure is unlikely in normal use, doesn't mean that this issue should be brushed aside IMHO. I haven't experienced ABS failure myself yet (touch wood) but somebody somewhere might, and thats not acceptable.
