G4
Hi all,
2007 year 1200 GS ADV just under 6000 miles, mine from new no problems until now.
Was out yesterday on it, did 50 odd miles stopped for about 1/2 hour got back on started her up and warning came up LIGHT F, and also ABS Fault. Checked front head light low beam bulb not working so thought change bulb when I get back, tail light and brake light working fine and though ABS Fault is up brakes also seem to be working fine.
Travel back home go to change front bulb, check bulb when taken out all working (still tried spare bulb the same) terminals to bulb also fine & clean. Starting to get pissed off
, disconnected battery left for half an hour reconneced turned the ignition on let it do its check same fault came up
but I did notice while the bulb was out & connected it did get power for a split second then nothing.
Any body had the same problem or idea of a fix before I resort to main dealer.
Looking forward to all the crap that I will now be sent ie. Sell the bike.
but I did notice while the bulb was out & connected it did get power for a split second then nothing.Any body had the same problem or idea of a fix before I resort to main dealer.
turned out to be loom cover worn on frame edge were there was a bit of rather sharp welding left,
