headlight adjustment
  • Thread starter Thread starter Allroad
Allroad
i think my headlight falls to low in front of the bike how do i adjust it upwords
cheers
On the back of the headlamp unit there is a lever to aim the headlight lower for two-up riding (see manual) maybe this is in the lower position.
When I picked up my bike, I could use it to spot planes :confused:
There are also adjusting screws on the back of the Headlamp unit, but no instructions for them in the manual !.
Piggers
my manual is fecked a flask of coffee broke in the top box have you any pics at all
cheers
There's a black plastic toggle at the back/bottom/centre of the light unit. Inside the toggle thing that's used as described above is a black plastic hexagonal screw, easy to see.
Screw goes clockwise to lower the whole unit's beam pattern.
A similar screw hovers around the rear RHS of the light unit, clockwise takes the whole unit's beam pattern away from the (uk) nearside kerb.
I've got a TouraTech cockpit cover fitted which makes em harder to see/photo but you should have no problem as they're obvious once you've spotted them.
Peter
