Heated clothing
plumbob
Oakham
Hello
I am thinking of purchasing a Gerbing heated jacket liner. I was wondering if there are any horror stories out there and will the 2009 R1200gs alternator cope without draining battery at lower rpms.
FYI
south east Irelands mountains were scuplted by ice ages rain and wind just for the GS it was one of the most freindly and fantastic riding experiences I have had. Also it did not rain for the whole 10 days.
I've got the Gerbing liner and think its very good - you need the temp controller by the way or it will get too hot for comfort. Bought mine about 3 years ago. You need to power it off the battery, not the accessory socket - it draws too much current for the accs socket (the canbus will then shut down power to the accs socket). I use a simple relay which is switched via a connection made to one of the wires on the diagnostic socket (this is the cylindrical device that lurks beneath the seat). Use a multimeter to find a lead that is live only when the ignition is on, then add a connection to this lead and use it to activate your relay. Or you could use the lead running to the accessory socket itself to switch the relay. A bit of minor bodging or a Scotchlok connector is required either way. You can buy a 12V relay from Maplin or Halfords for £2-£3. Get one that will switch at least 10 amps. There is a handy bracket under the RHS black plastic cover, by the air hose, that is ideal for attaching the relay to the frame (at least, there is on a 2004 GS)
If you can't be arsed with the relay, just connect the Gerbing lead directly to the battery. The lead is fused so it is reasonably safe if something happens to short the Gerbing socket when the jacket is not in use.
HTH
Forgot to say that I've had no problems with charging when using the jacket, but at low speeds through a city for example I'd turn my grips down to heat level 1. The jacket is usually running well under max even in sub-zero temps. The heat controller basically turns the jacket on and off for variable periods over a short cycle, so it goes from taking 70watts to nothing then back to 70watts, which is why the accessories socket won't cope (I think it is limited to 5 amps max so 60 watts)
Geribing heated jacket
Thanks for the reply that was exactly the information I was after though I may wire it through a second relay cotrolled socket rather than directly to battery (less likely to rip wires off when i forget to unplug, not that anyone has ever done that).
Have read someahere that jacket needs to be reasonbly tight fit or have a thin top over it to keep it close to body. I am thinking i need to by from shop rather than online so I can try on more easily.
Do you wear many other layers beside the liner?
I normally wear HG Tuareg jacket with original liner and a couple of T shirts when touring, heat only really needed beginning & end of season some times early morning. The Gs goes into winter hibernation from end nov to mid april so winter riding not needed.
PB
Carefull !
Hello
FYI
A mate of mine was out riding in Nov,with heated jacket and thin sweatshirt.
All was fine until jacket packed in he nearly froze to death on the way home,
so put a warm jumper in your topbox :)
I have a gerbing heated jacket with a heat controller fitted straight to the battery.
Worked perfectly for a few years now. I wear mine under my aerostich. You don't need it too tight, i wear mine as a light jacket when i get off the bike. Plus i wear it most of the year with the heat controller stored in the pocket, you don't need it switched on but it's very handy when it turns chilly unexpectantly, plus you don't have to carry a spare fleece "in case" it turns cold etc etc .
+1 Gerbing
I picked one up at their factory in Tumwater WA this past summer. Can't say enough good things about it and as StepToe says....you can get a more conventional jacket fit as it's so heat efficient. I too gacked my fleece and now wear the Gerbing when out walking off the bike. 100% percent waterproof....
Agree with Steptoe and Ron about the fit - it doesn't need to be tight, and it makes a good lightweight off-bike jacket. I tend to use it on top of a couple of thin thermal shirts, and underneath a Dainese goretex jacket. I put some Velcro on the back of the heat controller and fit it in one of the waist adjusters of the Dainese so it is easy to get to when riding. BTW, I bought mine online from Gerbing - if you call the Gerbing office they will help you get the right size.
By the way, the jacket and temp controller come with a lead fitted with a special gerbing co-ax socket. The lead can be connected directly to the battery or via a relay. The Gerbing plug and socket will separate before ripping out the wiring if you forget that you're plugged in. I've got the Gerbing socket fitted so that it comes out between the seat and the tank. It's trapped in place with a tie wrap.
Review of heated clothing in Bike magazine which landed on my doormat today. Gerbing gets most stars.
I have a Powerlet Proform jacket liner and gloves which I rate very highly - I had it shipped direct from the US. I have also just bought their remote dual controller which means there's just to one lead to plug in to the jacket liner for power and I can put the remote anywhere convenient again wirelessly. Its sitting on top of the clutch fluid reservoir at the present time stuck on with dual lock. Much better than loads of trailing cables. I'm pretty sure the connectors are the same as with Gerbings so you can mix'n match.
The Gerbings power feed, if live, doesn't like getting wet. If you hose it or pressure wash it, then stand back and watch it fry itself to destruction. The newer ones have a waterproof cap, the older ones, which are more common place are near as damn it useless. All protected with a fuse, but no good if direct from the battery. That's my only horror story.
Otherwise Gerbings heated jacket liner, with heated torso, neck and arms, is just fab, but you must have a heat controller or you will fry:D
Hello
FYI
Best heated kit as far as I'm concerned, got the whole lot for my wife including insoles, I've got gloves and sort of neckwarmer thing. You must have the controller and best get the dual one otherwise you can mildly burn your hand for example.
Jon
As an aside, I'd also suggest looking at warmnsafe.eu. They're very well known in the US (they invented the heat controller that Gerbings copied) but don't have dealers here, except for the european dealer in Sweden. I bought mine from him and the service was excellent. The remote controller is very good, I have mine attached to the handlebars and there's just a single lead to plug in when you get on the bike, and the controller's easy to reach.
Toasty warm.
As an aside, I'd also suggest looking at warmnsafe.eu. They're very well known in the US (they invented the heat controller that Gerbings copied)... Toasty warm.
+1.
Mounted my "trollers" on the dash... one for gloves, one for jacket. Double toasty:D
My 8 year old gerbing jacket liner went back to Holland as it kept blowing fuses, was advised to send the whole lot back, liner, on-bike dual controller and portable controller. Other than them screwing up sending the package back to me what arrived was a brand spanking new jacket liner. I like all the improvements over mine except perhaps the module for plugging in which is now a big old lump inside the jacket.
That said replacing a well used 8 year old jacket without quibbling FOC means they get my vote all day long. And NOTHING beats a heated collar :thumb
