Heated Grip - Circumference
Why, and which bit? They're not symmetrical, they're thicker in the middle than at the ends. How accurate do you need? They wear down as well. Mine are a bit worn.
Just measured mine. 11cm. Measured the diameter using vernier calipers then did some schoolboy maths to calculate circumference.
