Heated Grips
Dean2403
Kent
Hello guys,
Was out early on the bike the other morning, it was a bit nippy so I put the heated grips on. I noticed that only the right one is working! Is this a common fault with the 09 GSA? Is it an easy fix? Or is it a trip to a dealer type thing?
Dean
In warranty? Yes, then back to the dealer.
Out of warranty but you're not a DIY type? Yes, then back to the dealer/independant/friend who is a mechanic or buy one thicker glove.
Out of warranty and you are good with spanners - start diagnosing the problem - either the grip itself or the associated cabling/connectors usually.
Cheers,
Didn't think it would be as simple as I was hoping! Got a mate who's savvy with a set of spanners, so i'll get him to have a look.
Dean
As already said if it's in warranty then give it to the dealer.
If out of warranty then to be honest it is not that hard to do yourself, if I remember its just a case of taking off the hand guard, a couple of screws holding the switch unit to sepearate it and then unpluging the electrics. I used a simple bulb with 2 wires as a test unit to make sure power was getting to the grip then changed it for about £45 new from BMW.
Refitting is just as easy, all in probably half an hour job if you have never changed one before. :beerjug:
Top man - cheers! :thumb2
