Indicators and Heated grips stopped working?
Slime Bomb
Stoke on Trent
Washed the bike the other day then put it away as I normally do.
Two days later the indicators and heated grips have stopped working. No 'LF' on the dash either. Is this just water ingress that will dry eventually or could there some other cause?
Bike is a 2012 Gs adv.
Are both function on the same side. Sounds like a loose wire or connection into that side. I had similar issues with a BMW S1000R a couple of years ago. I just pushed the cluster loom back in gently and never repeated the problem. Good luck
None of them are working.
LF as in ??
have you put a GS911 on it and seen if there are any stored codes ??
My 2011 had a sticking high beam switch , new cluster proved the only way to fix it cost me £150 for a new switch cluster
You might find the rubber boots over the microswitches have split and allowed water in.
Thanks for the replies but it's sorted it's self somehow. When it happened it took a while to start so voltage must have been low. I guess this had something to do with it.
It hasnt ,
, its just given you the first warning that something is wrong, it will happen again, and then again
until your left stranded somewhere ....
