That's very interesting. Thanks for that Engineer.This intermittent behavior is typical of water ingress.
Here is my link from 2009!
An intermittent fault can occur anytime from a few hours to a day or more after the bike gets a soaking.
My particular fault was that the left hand indicator would stay on and refuse to cancel - however I believe that any of the switches in the left or right switchgear could show similar faults - I have heard of one bike where the starter was operating continuously after being ridden in the rain.
I dismantled the left-hand switch cluster and the cause was plain to see - the thin rubber 'boots' which were mounted over the white buttons were perished. These boots are designed to keep water...
- Engineer
- Forum: 1200 GS Hexhead & Twincam
. The switches when operated supply the 12v to the relevant pin of the ZFE. If you can measure volts at the ZFE pins when the switches are operated but diagnostics (GS911) don't see it then it is the ZFE itself that is faulty or its programming has become corrupted during your battery problems.
