- Joined
- Jul 14, 2010
- Messages
- 10,544
- Reaction score
- 3,962
Any particles in the oil will have dropped out of suspension and may be sitting in the sump as a thick sludge.Interesting approach, I am interested in what would be necessary to recommission rather than refurb. I see the logic in checking things out before trying to start it after such a long lay up but I have not done a pretty extensive strip down to recommission. Don’t get me wrong it’s the safest way but it was put away as a fault fault free runner and I was thinking more along the lines of fluid changes, sump drop, filters, bore scope, carb clean/rebuild. Run it and see what’s what. Are BMW’s more susceptible to deterioration during lay up than other brands necessitating such a strip down?
The piston rings may be rusty.
The cam and cam followers may have rust.
All of which will end up in the sump on start up,to be passed through the oil pump unfiltered.
Which may damage the pump and housing.
This is why I take this approach.
For the cost of a gasket set and a days work I prefer this method.
If something is found to be amiss it can be rectified.
