Humbug
No, the cable was initially attached to the plug using the crimp connectors supplied. As it didn't get hot I then soldered the wire to the supply cable, with no difference. I then attached the heating wire directly to various batteries and power sources with again, no difference. Replacing the wire has solved the issue so there must have been a problem with the wire?
