hi all
i got a 2017 gas and i put new brake pads in and now i got no brake pressure think i f**k it up big time can any one help I'm in walthem abbey essex
thanks
hi all
thanks
i did not disconnect any pipes
pump lever still have no pressure think theres air in there don't know how
never had this before on any bike just put pads in and go not this time
Possible with certain vehicle braking systems that if you physically force back the pistons without releasing pressure at the bleed nipple you can flip the seals in the master cylinder , never heard of it on a bike though
On BMW S1000RR its quite a common occurance on the rear master cylinder. Mine needs a new one because of this very problem. However it does not manifest itself as no brake pressure, in fact the pedal goes solid and the pads wont release the disk.
