Help! Dismantling rh switchgear
Not open for further replies.
Popell
Coming to a scene near you......, UK
got a small problem wiht the heated grip switch and need to dismantle the rh switch gear. all the screws are iout but its reluctant to come apart.
Does anyone know if I have to lever the starter push button off (or if this is possible) and remove the kill switch lever?
TIA
TIA
Remove the tiny screws form the back and small plastic plate exposes the switches. If you unclup the Cables and loosen the screws that attach it to the bars you can rotate to access. The kill switch has a brittle plastic catch that if it breaks is a bugger to fix.
Easier to work with after you disconnect the cables.
There’s a hidden screw under the label.
I know all this because Mark (merling)did a field repair on mine after it smashed. Replacing the broken one cost about £75 and didn’t include the tiny screws.
