Hi Shaunie,
Sorry, I should of been a bit clearer, As Mike O says if there is some slack the in the cable, problem elsewhere. The lever in question is the lever you operate with your left hand you will have to remove hand guards to check gap, gentle pull your clutch to take up the slack now measure the gap between clutch lever and mounting body of lever(you will see cable in between). It should be 5mm-7mm. If there is no slack ie cable tight, then move to rear of bike the clutch arm lever is found between your rear shock and the air box, the nut and blot can be a bit of a bast*&d to get at. then simply follow your manual to adjust clutch.
regards
jose
ps also check cable adjustment screw at hand lever I think it should be 10mm check with manual.
