HELP!..where do I plug this in?!?!??????
Not open for further replies.
SKIPSTER
South East.
Can anyone advise me on the following.
I have just bought down pipes and end can for my GSA, (recommended I might add by fellow TOSSERS!)....and i'm really impressed with the performance improvements.
Included with the parts is what can best be described as a piece of wire 3'' long, with a connector at each end.
Apparantly this part tells the ECU it is 10' cooler and helps smooth out the running?!?!?.......
The part number attached is ACC331352
It is worth noteing it came off a GS 1200 NOT a GSA.
I have looked under the left hand side panel infront of tank but could not see a likely place to fit it. (this area was advised by a friend!)...
Anyway, if anyone could share there wisdom it would be appreciated, :thumb2
cheers, ......:thumb2:thumb2:thumb2
..I shall have another poke around this evening, I hope the GSA location is the same as a STD GS
Thanks again.
