I am connected to net via wifi , and have got the iTunes on laptop . But when I try to use it tells me it's not connected to web , how and where can I look to switch on . Thanks in advance .
Like Bryn says, it's not an iTunes issue, your laptop isn't connected to the interweb.
Go to control panel>network sharing centre and you'll be able to see what's going on.
simplest way to test whether you're connected to the internet - open internet explorer, go to google and try a search. If it returns results, your problem is an itunes configuration issue (unlikely), if it doesn't, you have no internet connection (likely).
just because the laptop is connected to the wifi, doesn't mean the wifi is connected to the web!
Good luck...
if i wasnt connected to wifi would i be able to use laptop to use it on this site . i have no idea how these things works .![]()
This post is still on your laptop and hasn't actually been posted because you aren't connected to the Internet.
And for my next trick![]()
, what else can I do ,
I can't get secure link to iTunes .
Been reading that iTunes won't work with Wndows XP 64 bit . Pointless to keep trying . Any one got another disc set up that will work
