So, I fitted my new LED spot lights and a few other farkles, all done with no real issues then on to a quick oil and filter change. I had removed the tank to run a power cable up for the lights, so back on with the tank, fire it up.......oooh, that sounds a bit ropey.
Check the throttle cables, nope still in situ, mmmm.
Warmed the bike, dropped the oil, new filter in, top up with new oil, everything tickety boo, fire her up....dead!!
Bike turned over but no go. Check lines again and the link pipe and one of the fuel qr connectors aren't quite clicked home. Try again.....dead. Turns over but no go....
Checked injector signal, fine, but no fuel pressure. Pump is priming, there's fuel, but no pressure.
remove pump and whoever replaced the fuel filter had used the original BMW clips and the pipe had blown off the output on the fuel filter
Fitted a nice stainless jubilee clip, put it back together and she runs like a champ
Never had that before, so thought it may help someone in the future just in case you were thinking of reusing the BM clips, do yourself a favour and don't, or at the least make sure they hold the pipe on properly
