Sold Hexcode GS-911USB
INBOC
Member
Oxfordshire, England
Hi one and all,
Hexcode GS-911USB
7 Vin Slots remaining
Everything in the pictures included.
£160 please including posting Royal Mail 48 signed and tracked
PayPal friends and family or bank transfer please
Many thanks
INBOC
Hi INBOC,
I'm hoping you'll know whether this will be compatible with my 2017 '67 plate r1200 GSA. If so I'll have it for £140. I don't use Paypal but can easily sort out online bank transfer (First Direct).
Kind regards,
Andy
Hi INBOC,
Kind regards,
Andy
Hi Andy I will look into this for you and get back to you
Many thanks
INBOC
Hi INBOC,
Kind regards,
Andy
Yes it is compatible
If you have an OBD2 port then it willl connect directly
If you have the older 10 pin round port it will still work but you just need an adapter cable
Hi Andy (apologies if I’m teaching you to suck eggs at all)
21.50 minutes into the video the right hand side panel is removed (I know it’s a 1250 but the principle is the same) under there is where the GS- 911 is plugged in, he has the earlier one with the round end so has to use a short converter cable that has the OBD end on it to connect into his BMW.
So if you remove the right hand cover on your BMW you will either find a round connector or the OBD style connector as shown in my original picture.
If it’s the OBD you have then perfect, some of the earlier models of your BMW had the round connector
If the link below doesn’t open , type the following into you tube
BMW R1250 GS- Annual service! Oil, Final Drive! Brake Flush an Reset!
it’s by , illinoisBMWriders
Hope this helps
many thanks
INBOC
Thank you sir for your input much appreciated
I was typing out my reply , hopefully Andy will reply
Many thanks
INBOC
Hello INBOC,
Sorry for the tardy response, I wasn't monitoring replies on the Forum.
I checked the diagnostic connector and we're all good.
Do you want to send a direct message with relevant details for payment?
Kind regards,
Andy
Hello INBOC,
Kind regards,
Andy
Hi Andy,
No worries, I will send you a direct message with the details
Many thanks
INBOC
