HID and red triangle
Howard J
Who?
Chester
I fitted a HID to the main beam on my 2004 (with ABS) 1150GSA earlier, HID working fine, but I now have the red triangle light under the ABS light on, ABS works fine.
The light did come on a few weeks ago and I know it’s normally bulb related, so I cleaned up the contacts on the rear bulb and it was fine, so not 100% sure it’s the HID?
Can the HID cause the red triangle to come on?
If it's not the rear bulb, which it would be best to replace given the cost, could it be the brake light switch?
I'm out of date on these - is yours from the end of the servo era. If so that could be playing up or the reservoirs short on fluid.
Yes it’s the last of the servo’s 😬
Thank you 🙏 pesky little bulb 😂 it worked ok and looked ok when I took it out, but changed it and no red triangle light 👊🏻
