High Beam Adjustment?
gsbiker
Devon & Cornwall
Having riden my bike in the dark the high beam is useless. Seems like it needs adjusting because it isn't giving me high beam just better low beam. Can anyone tell me where the adjuster is or should I visit BMW?
Fit some Les Wassall HID's that will sort you problem out :thumb2
Else the center thumb screw tilts the beam up and down, the right thumb screw moves beam left to right
1. Have you got the lever thown for carrying heavy loads.?
2. Is your preload set correctly?
Have found the same thing - lights are pish. Aiming to get Wassalled in the near future, but until then... I think if you look in the top of the lever there's a screw which will adjust the the level of the beam...?
