I found exactly the same between my 2018 and 2020 GS' to the extent I hardly used it on my 2018 bikeMy 2018 bike required lots of revs to 'break away' and was a bit jerky. My 2021 bike is very smooth in comparison, I use it alot.
Looked at mine last week. It seems to have defaulted to Auto after the software upgrade, so the bike decides if you need it or not. Switched to manual and its back to normal again. Obvious when you know.......I shall take back my curse words.........Mines a 2021. Hill start was absolutely perfect until the latest software update, now it seems to come on if you even breath on the front brake. Stalled several times as I didn't realise or indeed need it to come on. I shall be going in and turning it off over the weekend.
I am not aware of any user adjustable settings ?????????How come I can't find those settings for hill start? I only have ON and OFF in TFT menu. My GS is 2021 with the latest software update.
I only use mine with the rear brake, sharp stab and it’s on every time, quieter selection of first gear and a smooth pull away with a little revs.I discovered today (by accident) that this feature can also be operated with the rear brake. I must check the manual and see if there is any reference to it.
NeilMine needs to go into the dealer to have the hill start looked at, has played up for the last two weeks when two up touring in the Alps ( when you actually need it ).
Randomly not engaging and when it does at least 50% of the time it is disengaging immediately and not holding the bike and when it is engaging it is then holding on when you try to pull away and being a pita.
Assume it is the microswitch BUT it coincides with the recall ecu update , any ideas
