flatdog
There shouldn't be anything stuck in the hole. It disguises an issue.
There shouldn't be anything stuck in the hole. It disguises an issue.![]()
Fill the hole with silicon sealant. Job done.![]()
Hi Shinyface.So where will the fluid end up then ?...............inside the casing to corrode and leak I suppose. ( no change there then )
Shinyface
(welcome BTW)
I had this coolant leakage problem. Was told by BMW that it would probably fix itself!!!!!
I,m an engineer and suspected that this would not be the case.
True to form I set off on a ride through France, Spain and Portugal. After nearly 3000 miles of constant dribbling
I got back home without the coolant level dropping by much but the bike is now booked in for a pump replacement.
Water pumps do not self heal, and should not leak on a bike that costs 14k
I sent this picture to BMW while away. Lol.
Sent from my Lenovo B8000-H using Tapatalk
Clearly not much of an engineer if you believed that BMW told you the leak would fix itself !
