Honda superbike
bustupbiker
North Wales
Well it started as a standard bike:augie
bustupbiker
Then things started to change:
bustupbiker
Big bore motor big valves too:blast
bustupbiker
Big bore Exhausst system:beer:
bustupbiker
I have to finish welding the exhaust up now it is tacked in the right place,
But! i have a little problem some body may be able to help me with. The
new Big Carb 28mm Mikini does not have the uel tap built in like the diddy one, so i am in need of a inline fuel tap to fit in the fuel line. Any idea's please?
More annon. Lyn.
Why! well i was going on a Looooooooong Charridy ride that is now NOT
going to happen, so i pulled the standard motor out to play with the scoot,
only 6thou so it needs to stay that way as i may well give it to the scoots
charridy after play time is over....
I cant wait to see how this turns out :D
Good Luck and do keep us posted. :thumb2
Sweet:D
I've always fancied another C90 to mess on with. Used to bray round the fields on one when I was a nipper:)
Yep ...
The new Big Carb 28mm Mikini does not have the uel tap built in like the diddy one, so i am in need of a inline fuel tap to fit in the fuel line. Any idea's please?
.... don't bother fitting one, after the first useage for old times sake the fuel taps very rarely get disturbed :nenau
As i said i was going on a looooong charidy run that is now not going to happen:tears so i thought i would have a bit of fun with it. I have been
toying with the idea of some Ard Cases and engine bars some tour-u-twat
type stuff, Hid the head light:D it all has to go back to standard thou cos
it's too good to cock-up....too much time on my hands now i have retired.
Got a small tank type fuel tap from the lawn mower place:augie qwik file around the tank entry threads and bingo it works, can't see it under the leg sheilds so all is well. I will finish the exhaust Sunday and give it a kick into life....:JB
Well the exhaust is welded and on the bike ( sorry, Super bike ):augie
Leg shields trimmed to take the new Big air cleaner:blast
Just called to dinner so pics in a bit.:thumb2
Don't no what i did with this but i did it twice..
Zorst fitted and ready to kick into life.
The Big air filtre, so i can't hold off forever so here goes.....
:eek: sh1t! it fired up second kick, tick over is too fast slowed it down cos i could not get it into gear. Let it run a min or two and stopped it to check the oil level:thumb2 10/40 super Kawasaki stuff, that should make it go well.
I did a bit of fertling and got out the lid, the moment had come at last for the
test ride:eek went up the road to the roundabout and back, did'nt check the tyres...12lbs in the front and 18 in the rear:blast:rob
Fixed, up to the post box to throu some letters in and away Owwww! two
miles at 30mph:mmmm had a coffee at Pats sons garage and headed home.
Now did i say the 125cc BIG motor has 4 gears not three:blast 45 mph this time....at half throtle too:eek:
I think i will order the 17 and 18 tooth front spockets and try them as it seems to rev a bit too much, not the clutch, it's too qwik on take off and up to 45mph:D Well thats it for now, getting the bug for this tinkering, now where did i put the bits for Rickman Zed bike...:beerjug:
Lyn.
PS: why have the pics gone all diddy.?
I think i will use the Ped through the summer as i will be doing some work at the Lads garage this year, then i may chuck the standard motor back in it and give it to the bike charridy lads to take to Africaaaaaaaaaaa:thumb2
But i will get a leg sheild first..:beerjug:
Nuver thing i found out when on the test ride, all the bloody gears are up on the 125 not down like the 90:blast think i need to adjust the clutch to as it's a tad hard to change gear. Mind that may just be me, not being used to this sort of POWER::D
