Hornig wireless charging pad
tspivey
Kingston upon Hull, Yorkshire, England
Just bought and fitted the above to fit in my R1300GS cubby hole, only 37.51 euros including post and arrived very quickly and with no import tax. Ordered on the 21st, arrived 25th.
This pad was mentioned in the @Smartbazza ‘New 1300’ thread but I didn’t want to distract from that.
I’d queried in that thread if the charging would work through my thick leather Snakehive cover (iPhone 11), it does 👍
The only minor issue I’ve had is that I had quite a few cards in my leather cover that made it slightly to fat for the lid to shut, works fine with just a couple of cards.
Thanks @leadfarmer 👍
Post a link for the lazy among us !
I bought this and noticed when i was using it i would get key missing errors on the R1300… I changed the batteries and same. I removed the wireless charger and went away. Made no different if key was in my jacket or the tank bag. Be interested to know if others get the same
Interesting, since fitting mine I’ve had two false front tyre pressure warnings on my 1300.
Yes, I have had the same problem when wirelessly charging a Pixel 7 phone. New batteries in the key fob made no difference, so it looks as though it is probably related to the type of phone being charged. Will try it with another phone and see if it occurs again.
Perhaps the wireless charging pad is transmitting radio interference.
Same but cheaper out of amazon. Seems to work perfect with my S25 ultra... I have a case for magsafe so the phone stays put magnetically too.
Accidentally came across this post, you might have solved my key problem and rear tyre pressure monitor. My key constantly says not present (Initially lead to believe it cause the key goes to sleep) even when in the tank bag and the rear tyre pressure doesn't show a reading more than it actually works. The dealer told me it was cause I had a Ezcan fitted which BMW are not a fan of apparently. Will have to try it without the charger in. Don't suppose you know if using a cable and your phone in the cubby hole interferes at all?
My problems disappeared after a software update at service.
So a quick update, when using the Pixel 7 in the charger the key loses connection, with a Nokia XR20 no issues. So the wireless charger is coming out and it will be just wired charging from now on for the Pixel 7.
Did it give you any problems with the TPMS?
