How hard can it be ?
RedRick Esq.
Telling Engineer to F**K off and blocked by PP
Far right adjacent
To do your own Servicing
Having aquired a Haynes book of knowledge i figure that it cant be too hard with the advantage of knowing that i have used the best of evertything I.E K&N, Irridiunm plugs and the best oil etc plus having the pleasure of tending to my bike for considerably less money.
So what is the considered opinion on here,is it a worthwhile endeavour ??
If you are keeping it fine
But home servicing will reduce the value at least if selling or part exchanging to a dealer but then you will have already saved some cash so swings and roundabouts really plus the second hand market is awash with bikes at the moment some attracting no bids on ebay etc (did you see what I did there as I'm looking for one but keep it to yourself):D
Absolutely.
Apart from being seriously cheaper, it will help you get to know the bike, which means in turn that if anything does go wrong on the road, you've got a far better chance of identifying the problem and fixing it.
Getting up close and personal with the bike will also mean you get to see things that are potential problems....weeps that might turn into leaks, rubbers that are wearing, cables fraying etc.
I'd say don't start by using the manual...it's certainly worth reading through, but if you have a friendly independent near you, next time you go for a service, take a big bag of doughnuts and watch what he does.....seeing an expert do things in real life is infinitely better than following theoretical instructions in a manual.
Start small, get confidence, work your way up the scale of difficulty :thumb2
There will probably be many tossers around you willing to help as well......if you have a job to do, stick up a thread asking if anyone can help and that you'll provide bacon butties and unlimited tea. :D
A bike you've serviced well yourself will run better than a bike that a dealer has serviced to their BMW schedule........for example, if you ask for a valve adjustment, that's what they'll do, and they'll do it to within the fairly generous tolerances as set in the book.
If you do it yourself though, you'll also do the float end gap at the same time, and you'll spend as long as it takes to get the valve gaps and balancing spot on......People like Steptoe will do this as well, but a main dealer won't, unless asked specifically.
Go for it :thumb2
EDIT...
Disagree.
I'd put more faith in a log book filled with receipts kept by a decent home servicer than a dealer stamp.
You can tell more about the way a bike has been kept than by seeing that the previous owner can remember a date :)
Maybe it's time for another bike maintenance school up in these parts I'll look into securing a venue ;)
Absolutely.
Go for it :thumb2
EDIT...
Disagree.
Yes i get the re sale bit but as i have spent good money making this bike as good as possible
Hill topped, willburs etc etc and i do intend to keep it (ive heard that before)
the point made by Fanum is what i was getting at really i feel i could do a better job or more caring job than the dealers
You've gone wrong from the start. K&N is far from the best.
Nor is the Haynes, two mistakes to start with, get the BMW CD workshop manual keep the Haynes for a door stop!. If and when you see a Clymewr for 1200's grab it as these are the dogs wasits' (or better still send it to Steppers).
I have the BMW workshop[ CD down loading as we speak/write and seriously WTF is a Clymewr
And i would take it to Steptoe if he wasnt so far away !
He means Clymer
And for a more local Indie dealer.....try ABW here
Have a search on them on this forum....I've not seen ANY bad reviews and they are run by Tossers from here :thumb
They're in Swinton Mancs, so a fair bit closer than Mr Grumpy Steptoe :D
I'd of thought it might be available here to subscribers as per other bike sites..
Most of those CDs will be illegal pirate copies.
Fine if you don't mind a bit of theft, and the BMW ones are certainly out there to be found really easily......but being gentlemen motorcycle enthusiasts here, it's a bit more discrete ;)
I have the BMW workshop[ CD down loading as we speakQUOTE]
Where did you get the CD from?
There was a thread on here this morning with a link to a well known torrent site that many ISPs have blocked
of course I would not download in such a manner as it would be illegal
He means Clymer
Yes ABW are just over the hill
i have been using my local independant bike servicing blokes ( they are a good pair that seem to do a good job ( i have taken dough nuts and watched them) i just fancied doing it myself
As we did previously :thumb You get the venue and i'll spin the spanners.
Right time of year as most weekends are accounted for during the summer.
