Can't believe yet another GS has been stolen! Crap!
I now chain mine up, but i'm unsure of the best routing for the chain(s)? I'm trying a few different combinations but i wondered if this is something others have thought about and solved? This is for both use with a ground anchor and for those stops away from home...
. Failing that, do as Tim says ,using the wheel and stand.
) as this stops the scrotes lifting your bike into a van - unless they have had enough Shredded Wheat to be able to lift two bikes at the same time!
