How to set the clock
gsarider
lincs
hi i have fitted a new battery on a pre august 2006 r1200gsa obviously the clock needs re-setting. i have tryed the holding down the button but it just changes the trips? Any tips. Carl
Here you go ...
Switch on the ignition and use the button ontop of the left hand switch gear to get the clock showing.
Then hold down the button till the hours start to flash and then press the button till the correct hours show, then press hold again till the minutes start to flash and repeat.
spike
As per Spike's suggestion :thumb2
On my June 06 GSA you change the clock time by pushing down and holding the BC (Board Computer) button. Pushing the rubberised button by the clocks only changes between the trips. Holding the same button down resets the trip meter!
The problem is clearly a taxing one.
But from adversity comes opportunity. Leave the clock as it is. Take your watch and look at the time. Compare the your watch's time with your GS's time..... you now know the difference between the two.
Each time you look at your bike's time, subtract (or add) a suitable number of hours or minutes and all will be well. This simple mathematical exercise will serve to stimulate the neurones, serving ward off piles and syphilis. Do not forget to make a suitable adjustment of one hour each spring and autumn when the clocks change.
