steve16
.....fitted and no problems or so I thought ! Noticed small streak of oil coming from the plug I fitted as part of the fitting kit (Its the one on the main shaft housing).Checked with BMW Park Lane and they confirmed the hole is or rather should be just a fixing point for the rear mudguard/deflector (now removed in favour of hugger).The oil was leaking down onto the wheel so thought I best mention it in case anyone has the same peoblem,I have removed the plug and refitted the screw so hopefully that will sort it !!!!!
Steve
Steve
