Hunting??
X21ekx
North Yorkshire,England
Morning peeps
Question?
The last few morning(not particularly cold) I've started the bike up and it's been fluctuating between 1 and 2k rpm?? Without touching the throttle(hunting for revs)
A couple of times it stalled just shortly after leaving the house, once it's been ridden for 5/10minutes it's fine??
Anything I should be particularly looking at?
Cheers in advance
just check you have not lost one of those rubber blanks on the bottom of the throttle bodies,the ones you take off to balance the throttle bodies :thumb2
Check for moisture in the TPS plug on the side of the left TB.
Sounds exactly like the symptoms I used to get when I had a PCV due to sealing issues. Which is why I don't use it anymore.
After a cold start mine was ticking over at 2000 rpm but not hunting.
I couldn't find anything wrong and once warmed up it was back to normal.
I have a PC-V.
Wrapping connectors and the unused O2 sensor sockets with self amalgamating tape seems to have kept the weather out.
Find a local GS911 and check the real time values, Idle actuators vs throttle position vs rpm, might show up a vacuum leak.
But first check the air temperature sensor is reading true.
Intersting point. I suspect mine under reads but only by a degree or two which I doubt would make any difference to cold starting tickover speed.
A couple of degrees will not make any difference as the BMSK Will adapt this out.
If you have disconnected the lambda sensors to fit a PC 5 this will not be true but you will be able to correct it with the PC 5.
When I said reading true , I had a bike in that was difficult to start when cold and would not run properly until it was hot.
The air temperature was 10 deg C the GS911 showed the bike reporting air temperature of 60 deg C.
Changed the sensor, Job done.
