Bryn Well-known member Moderator Moderator Joined Sep 20, 2003 Messages 14,077 Reaction score 512 Location South Leicestershire Sep 22, 2009 #1 Anyone know if you can retro fit/swap a standard 1150 GSA spring with a Hyperpro spring for the 1150, and will it drop the ride height a little? Ta
Bryn Well-known member Moderator Moderator Joined Sep 20, 2003 Messages 14,077 Reaction score 512 Location South Leicestershire Sep 22, 2009 #2 I'm led to believe no The shock body is around 2 inches longer on the ADV
Sir James Rear Stab Vest Only .... Joined Aug 6, 2005 Messages 7,557 Reaction score 0 Location Independent State of Burtoria ... Sep 22, 2009 #3 Bryn said: I'm led to believe no The shock body is around 2 inches longer on the ADV Click to expand... Get yourself a Wilbers shock , everything is shortened , even that rod bit that goes up and down git fast as out on them bumpy bits
