I have a lock, but not a key ...
Nin
Abingdon, Oxfordshire
Hi folks
A bit of advice required. I have an ignition lock that came with my ‘83 G/S, but sadly don’t have a key.
How do I get one ...?
Has it got a code on the lock barrel...... ?
There’s a 4 digit code etched into the base of the ignition lock.
IIRC, BMW can supply keys, against the code, with you providing ID & V5 etc. Sounds expensive; I see talk of £40-50.
The alternative would seem to be to order a key blank, from say Motorworks & get a locksmith to create a working key............unless you feel brave enough to DIY: -
............ https://www.youtube.com/watch?v=5P120yIWEIw&feature=emb_logo
Perhaps Steptoe/Mikeyboy can assist?
just looked through a pile of old keys. I have a AA15232 and a AA51243 both neiman keys.
I did this but then the blank with its turn-down end wouldn’t fit any of the key cutters vices to get an accurate replica of the one key I did have. :blast
Just a thought.
Many moons ago, I fitted I concealed switch and used that. Even if bad men screwdriver the key the bike wont start and you then wouldn't need to buy one.
Have a search around a friend of mine found a locksmith/key cutter that made/ cut keys from the lock for around £20
Just a thought.
Oddly enough that’s just the plan - a hidden barrel key for power and use this just as an ‘on/off’ switch. I’ll see what the local lock smith can do.
Thanks all
Nin
