I is hidded I is
mr badger
The Exotic East
Took my life in my hands and fitted up one of Les's HiD p&p kits today.
All worked out fine, no issues and worries about taking bike apart ill founded.
If I can do it, anyone can. If you've been putting this off - don't wait any longer.
Done my GSA main and high beams with one of Les's kits - no problems just can't really test it until I get my puncture fixed :blast
I've just pm'd Les with a query about fitting the kits to OEM fogs - but in the meantime was this something you did and how/where did you attach the ballast leads into the original wiring?
No fogs yet. Ballasts fitted to one of Les's brackets. P&P kit has pre-drilled caps, ballasts fitted to bracket and easy instructions.
Thanks, I'll wait for Les to get back to me - the fogs kit doesn't have pre-drilled caps and needs the OE connector cutting off I think - just needed to check a couple of things before I started drilling/cutting :augie
No longer scared of the dark.
Finally got HIDed.
Took a ride up to Les Wassall this morning, to have my dip and main converted.:bounce1
Not being technically minded, I decided to take up Les's offer to fit them. :D
I know it was the easy option, but Les has done a cracking job, much better than I could and a damn sight quicker too. Quality, from start to finish.:thumb2
Couldn't wait for it to get dark!
Wow, what a difference, wish I'd had it done ages ago.
Thanks Les.:clap:beerjug::clap
