Who's got the horn!
Simple, run two cables direct from the battery on positive and on negative fuse the positive lead at the battery. Connect the new relay to the existing relay so the horn button operates both, then connect your new horn to the new relay and away you go. It is necessary to run two new cables as the current is high and any volt drop along the cables will mean the horn losing power and when you've only got 12 volts to start with loosing one is bad news!.
dave GS
dave GS
