ice in petrol tank
bart2181
birmingham england
anyone know why theres huge blocks of ice in my petrol tank,i,ve just removed the inards whilst doing a tank change and wondered what the noise was whilst shaking the tank about,next thing i know theres a huge block of ice droppod out.i thought petrol was,nt supposed to freeze
Sir has water in his tank... it happens.
treat it with a dose of Wynns 'dry fuel' every 6 months and that will go a long way to controlling it.
otherwise you will have problems.. water in the fuel and then getting into the injectors isn't nice.
Do I assume the weather is a tad chilly?
Not a problem here currently :comfort:comfort
Also a bit suprised, you must have had contaminated fuel?
just a thought,when i took filler cap out there was no fooooooking rubber seal under the filler.is that the culprit,looks like some cowboys done a bodge job in the past:confused:
could be - could also be that your drain tube is blocked - thats fairly common too.
Ice
Probablu 'cos it's bloody cold!.
Very serious too!
Easy to check out though. There are two tubes under the bike. Both are overflow pipes. Find them. Smell them:drool
The one that dosn't smell of petrol is tube that's connected to the filler cap over flow.
Clean this tube with a rag and blow as hard as possible ... you may find a large piece of moss or other dirt suddenly flys out of your filler cap.
Stopped water getting into my other bike. BMW didn't check it. Their good about replacing injectors though:augie
