Agothaclypse
Appologies if this is a stupid question.
I have a 2001 1150GS & I am wondering what the idiot (telltail, as BMW call them) sequence should be.
When I turn on ignition & deactivate imobiliser, only the neutral light & ABS lights illuminate (ABS flash together until moving off). Oh, and the RID lights up.
I would have thought that Low fuel, Battery & oil pressure warning lights would illuminate until engine started. In order to let one know that they are functional.
With engine running, indicator & high beam warning lights operate fine.
I ask because the owners manual states that when you get to 2 bars on the RID fuel level meter, that you are on the reserve 4 litres & that the orange fuel light should come on. The other day I took the fuel level as low as 1 bar & the orange light did not come on.
Is this normal ? Please illuminate me (scuse the pun) oh wise ones.
If not normal, any suggestions on how to trace/cure the problem.
Thanks in advance
Paul.
Thanks in advance
Paul.
