mavis cruet
i have been trying to check the timing on my 93 r100gs (electronic ignition i think) with a strobe. i can get the 's' in the timing hole (a tad low). when i increase the throttle it rises, but the 'z' that is supposed to replace it is no where to be seen. the bikes twin plugged and i know the 'z' should be a tad lower than central in the timing hole. do you think a tweak of the bean can will solve this? (dont want to faff tonight as in case i bugger things up as i need to get to work tomorrow) could it be the bean can is buggered? dont really want to buy one just to try as they're quite expensive. cheers in advance. karl
