Paul Dilley
Advice requested on ignition timing method/s, either static or with strobe.
1150 single spark model
Welcome Paul to the mad house, here's where I put my foot right in it...if so Steptoe will help out...I thought as this is electronic ignition you had no need to adjust the ignition timing.....had a look thru my 1150GS manual and it does not appear to mention it...so come on guys right or wrong...?Paul Dilley said:Advice requested on ignition timing method/s, either static or with strobe.
Mick_rw said:Thanks for putting me right on that, after reading your procedure...looks like a job for a dealer.....![]()
Mick
Mick
Hi guys,
Sorry to drag such an old thread back up, but it seems appropriate!
I have a 1150GS here, and the hall sensors threw up a fault code (wiring failed, quite common I understand).
J
Sounds like old vectras that stalled, they would log crank sensor codes.That's unusual as they don't normally show up as a fualt, well actually they do because the engine isn't running and every bike shows a hall sensor fault even when they're 100% working .... But you knew that didn't you ? Didn't you ?![]()
