Haych - this is exactly the information I believed I needed when deciding on the advance curve for the ignition unit I'm using to replace the Motronic set-up with my carb conversion.
I tried to get an idea of the standard advance curve, but it was impossible, as Frank says, the signal from the Hall sensors is intercepted by the Motronic box, which then enters other variables, throttle opening etc, into the equation, and then varys the timing accordingly. Even when strobing under load, the advance seemed to be constantly moving!
Assuming your Hall sensors are problem free, the only way of verifying the advance is working correctly, is to get a BMW dealer to perform a test on the Motronic box.
