I also lodged a claim under warranty ror a new windscreen. Was told by my dealer herein SA that BMW had apparently redeveloped the brackets for the screen and that they are now bigger than the stock ones. We don't know however when these new brackets will be at hand though. Have you guys maybe heard anything about this?
What am I getting myself into!?!?!?!
I am doing my best to get rid of the flies, there are now a lot less since my return trip from Yorkshire last weekend.![]()
Might be an idea to fit the Cymarc screen support brackets as it stops the majority of the flexing and I'm guessing that's the root cause.
I fitted a set and for £42 they are a good bit of kit.
Jon![]()
They are on my list of things to buy for the GSA but the way people seem to be going through screens maybe BMW will make Mark Hooton an offer he cant refuse or buy me a set to save on warranty claims
Highly recommended mate. Makes such a difference![]()
If the Bolts are over-tightened the screen will crack. Exactly the same thing happened to a few earlier GSAs if I remember correctly. Personally I would use a thread-lock and don't tighten the bolts to the point where the rubber washers compress.
do the screen brace things prevent the screen being adjusted on the move ?
Yes and nowith the screen brace locked it will prevent adjustment. If you loosen off the locking wheels then you can adjust the screen on the go.
Jon![]()
