So I've read all that.
Apart from an 'irritating feeling', what is the problem?
.... And is he really sure it will stop bugging him at twenty thousand?
Of course it would work. I hope that you have enough muscles to excavate it and haul it off the beach at the next low tide.
Whelk, good luck, let us know how you get on.
Yes and don`t get Crabby if it doesn`t work![]()
I'm not shore it will work. We'll sea.
the seaside always makes me feel better
FFS, lots of peeps with nothing better to do![]()
thanks -obviously I am aware that the link is for a boat engine but I thought that the diagrams and explanation of glazing was helpful since the general idea is the same. I have come round to thinking that the bores are not technically glazed ( which can only be cured with a honing tool) but that the synthetic oil is slowing a bedding in between the rings and bore. So I have ordered some mineral oil from opie and am going to see how it goes for the next few thousand miles. will update this thread with my progress.
I discussed this with a BMW motorcycle mechanic when they changed the oil recommendation over. He told me-
They were copying their car section, It does take a lot longer to bed in the engine, often 30 to 35k on the water cooled cars, but they had found that warranty claims had dropped.
He recommend to me to use part-synth oil to 6K and not to be too gentle with the engine. (This was before it came installed)
I ran mine in with the wife on the back accelerating gently up any rise in the road and on motorways and dual carrage ways changing speed/revs every few miles.(as per book) After 1000 mile service (recommended by A Jefferies not 600) Used a recommend from someone one on here to rev it really hard at least once a ride after it was warm. Worked really well, uses lot less than a liter in 6000 miles.
Nick
as for those bemused by why I should be irritated - having spent £14k on a bike it doesn't seem unreasonable to be concerned about less power, more running expense, having the hassle of finding, carting around and continually checking the oil when I know from previous experience of the same engine it doesn't have to be this way.
Ran my 2010 in more gently than the new GSA
GSA was run in two up backwards and forwards over the penines and not sparing the horses.
Thanks -That makes sense. Can anyone explain then why more oil seems to drain into the sump when the bike is on its side stand. This has been my experience and is born out by several other recommendations on other threads. Obviously what I am talking about here is a like for like level comparison on the centre stand with and without a prior period on the side stand.
What? The cooler can't 'drain' unless you open it's piping to allow air in, it's a hydraulic loop so stays full of oil.
And 'glaze' is a polished effect of the walls of a cylinder bore, and unlikely to of been achieved in your engine. Removal of such a glaze requires the use of honing stones mounted on tooling that needs to be spun in the bore. Running the engine ain't going to do it.
The boxer engines have a trait of oil consumption during the early life. This tapers off as the engine beds-in, my own 1200 was thirsty until 8000 miles and from there until now, 21,000 miles, has been fine.
Buy an LC and you won't have to worry about oil consumption ever again, cos it doesn't use any![]()
I suspect the oil drains from the beak mounted oil cooler when on the side stand before the oil thermostat cools and closes, but not when on centre stand. Just a hunch, no facts to it but I too have seen more in the sump if left to cool on the side stand than centre stand (once checked upright).
Sent from my iPhone using Tapatalk - now Free
