Indicator relay
Posh Pete
Still got a pulse.
Embra, Scotland
I suspect the indicator relay has gone phut on the GS. Before I order from MW, is there an alternative unit that can be got locally?
Take it to your local motor factors and ask.
I put one from a Mini on a Yamaha back in the 1970s.
Stop the bus! Whipped off the tank and gave the relay a couple of dunts! Fixed. For now at least!
I should have thought of that! Ta. :beerjug:
If you do need a new relay, consider a solid-state one. They blink at a fixed rate irrespective of load, so it makes fitting LED bulbs simple. Vibrations on my (non-BMW) twin killed indicator bulbs regularly.
Examples that probably won’t fit! Got mine off Amazon for £6.
HTH
HTH
Thanks. I'll bear that in mind for the future. It would be great if the Ferrari one fitted! :D
