Inner Dia of the fuel line / pipe 8mm or 6mm for gs 1150
If you find good priced metal fuel connectors. Give me a shout Mr moonhead.
Please xxx.. ;)
plastic ones are cheep on ebay. its the metal ones im wanting put im not willing to pay 40 quid for both fuel lines
My thoughts as well.
That's what I thought you had in mind ;)
If you've got the all plastic QD fittings, you only need to change the male part which is now metal as standard from bmw. I'd recommend changing then sooner rather than later. When that male part breaks it involves an awful lot of swearing and is nigh impossible to fix on the roadside (unless you're already equipped for exactly that eventuality). DAMHIK!
Sent from my SM-N910F using Tapatalk
thats why i thought them brass barbs would be good to carry on long trips
I get your thinking, but with the metal male part you'll have eliminated the problem .
Saying that, they still look like a good addition to the tool box.
Anyone know if my 1100GS has 8mm internal fuel lines ?
I went to take my tank of last night and found out I dont have any dry break, quick disconnect s fitted.
