Intaride EVO 1 and Nokia N95 8g
Marks adventure
Through life
Hertfordshire - England
Just got hold of a evo 1 with bluetooth.
1. How do i set my phone to auto answer
2. Can i set my phone to connect automaticly when in range of the bluetooth?
:rolleyes::rolleyes::rolleyes:
have'nt got a nokia but it's in the phone settings somewhere, just leave the bluetooth switched on on your phone and it will re connect to the evo when you are within range.
Yes and Yes.
To pair the Evo 1, plug the pairing pin into the phone socket of the Evo and power up, then after 4 seconds remove the pairing pin. Now do a search for bluetooth devices, when you find the Evo pair with it (think it's 0000 to pair), once paired select options on the Evo connection and set to authorise, this will connect automatically once the Evo is on and the phone is in range. If you leave the pairing pin in until after the pairing procedure it means you don't get the annoying beep every five seconds in your headset as the Evo searches for the phone.
To set the phone to auto answer find your accessories or enhancements, select headset and change to auto answer.
