Went to get papers on Sunday, came out bike would not start so bumped it.
Got home - starts fine, for a while.
Symptoms :
- when it starts all seems ok - no nasty noises and battery is definitely not flat.
- when it doesn't start, the relay clicks so not the switch. The panel lights dim very slightly - so its not pulling heavy current like if the starter is jammed.
Any clues folks - could it just be the relay, would it be worth changing this before I dismantle to get at starter ? How to check ?
Thanks in advance
Mike
Symptoms :
Thanks in advance
Mike
