Hi
Can anyone help? I have an intermittent starting problem. Sometimes the bike goes through its checks when ignition is switched on, then when starter is pressed nothing happens. It makes no difference if the side stand is up or down. The bike is in neutral and the gear indicator work fine. It can take me ten minutes to start, switching on and off to try again. Any ideas?
