I've just converted my fogs and spots to 35w hids.
Previously, each spot or fog was wired using 14 gauge wire, which has a rating of 6A.
I'd prefer to run single wire to each pair of lights and, at 35w each (total 70w per pair), they pull 5.8A at full power.
That should be ok according to the wire table, but I just wondered if you should have a bit more capacity or if it will be fine as it is.
I'm connecting the wires to AMP Superseal quick disconnect connectors so it's a lot easier just having 2 wires per set rather than 4.
we've all been there at some point
